Zone12
Zone12
Filters: 14
I just have a couple of problems with the UI. I think it should be more graphical oriented.
- There should be two types of controls.
-- A 'user control' for modifying settings in the main window and edit window.
-- A 'filter control' for modifying settings in the edit window only.
-- This could be toggled with a checkbox on the control so you don't end up having two of each control.
- All the components should be edit in place. You should be able to:
-- Enter data directly into a control (or right click to change control settings).
-- Right click on a property and enter the value directly.
- There needs to be a dropdown control type.
- Each of the components should have a checkbox for each parameter to put that on the main window without having to use a component (which would remove a lot of clutter).
- There needs to be limits on the colour control (I may want the user to pick a colour which is a certain brightness which currently uses extra components and time when rendering), and all other controls.
- There should be a side by side comparison mode so you can see a before/after version of your image (either two whole images or half and half).
- In the filter editor, the panel on the left should be resizable so you can see more/less of the image/ and should be collapsable like the component panel.
- There needs to be two more levels of zoom in for people with high resolutions.
- Lastly, the lines between controls should be of a type: straight (current method), L shaped, S or Z shaped and the line should be able to start from the top, left or bottom sides of the component and be moveable. With some of the filters I've seen it's hard to modify them for your own use or understand how they work with lines all over the place.
Zone12 wrote:
- There should be two types of controls. -- A 'user control' for modifying settings in the main window and edit window. -- A 'filter control' for modifying settings in the edit window only. -- This could be toggled with a checkbox on the control so you don't end up having two of each control.
Sounds like a good idea. I thought about this some time ago, can't remember the reason why it didn't make it into the final interface (probably, the reason was the confusion this feature may cause).
Zone12 wrote:
- All the components should be edit in place. You should be able to: -- Enter data directly into a control (or right click to change control settings). -- Right click on a property and enter the value directly.
One of the first interface mock-ups had the in-place edits, but it added too much clutter, so we scrapped it. Also, it would interfere with component selection and dragging. The right-click idea sounds interesting though.
It was on our plans, but was dropped due to time constraints. Plus, it wasn't very easy to use. Maybe we'll introduce it in later versions (and I'm sure the programmers won't like this idea smile:D ).
Here's a quote from an earlier discussion:
rilos wrote:
Wouldnt it be easer to provide a flag with each relevant input field to say I would like this setting in the final filter control ?
My answer:
Dedicated control components have three important advantages over this:
1. You can use Remappers to specify how exactly the conrol component affects the input it is connected to.
2. You can control multiple inputs with a single Control component, and each of these multiple inputs can be Remapped.
3. You can give the control a custom name (localizable in future versions).
You can use the Show Original checkbox on the Toolbar.
If you're talking about the Editor, the next update will add one more level.
13 unregistered users.
