pafonk
Hello,
I'm building currently a new texture library and it would be a great time saver if filter forge can render the additional maps automatic in some kind of batch processing.
Peter.
Peter, please take a look at the batch renderer functionality.
pafonk
GMM,
Thanks for pointing me to the help smile;). Any chance to get a normal map example?
Peter.
Sorry, don't get what you mean. Any chance of what?
pafonk
The scripting example shows how to generate a color map (texture). I can't find the syntax for a bump, normal or diffuse map. Is it possible to get one or two additional scripting examples?
Thanks,
Peter.
Peter, that's more to the filter than to the batch script. The attached script renders a bump, a diffuse and a normal map from the attached filter. Make sure you've corrected the paths in task.xml before you run it.
Copy of Crysta.ffxml
Update: Grr, the forum doesn't allow me to attach an xml file! Please use the attached .txt as the task file.
[ task.txt ]
pafonk
GMM,
Thanks for the example script. This will give me a head start for the further scripting process smile:D.
Just awesome,
Peter
