ronviers
lighter/generalist
It would be nice if the ‘L-Range’ control on the pattern components could be set to range between positive and negative values.
@ronviers
What would this give you, an inverse range, where all the lighter tiles would become darker tiles and vice versa? What are you trying to use this for?
ronviers
lighter/generalist
I wanted to have as much push as pull - some sticking out and some sticking in.
@ronviers
ronviers
lighter/generalist
It's easy enough to do manually.
shftRng a.ffxml
@ronviers
ronviers
lighter/generalist
test
@ronviers
ronviers
lighter/generalist
There's probably a better way to do that but I am not very good at math. smile:|
@ronviers
subtract 0.5 and multiply by 2x, x being the desired maximum height
ronviers
lighter/generalist
Thanks. smile:)
@ronviers
