I use FF alot....dream of components, scripts, and new things that I can create with it in my sleep smile:D ....and I think the following enhancements are currently the most needed for this program (behind 64-bit support)....
1) Control Locks for Randimization: More than much needed....not having them makes it impossible to use randomizer to zero in on things with all the controls changing each time you touch it. Further, having control locks would be very useful towards testing and isolating problems in the construction of filters as well....
2) Disconnect global Size, Pixels Control option on all tied Components: The issue has always been to have the option to disconnect certain components so that the global Size, Pixels Control doesn't break the filter effect....not to totally disconnect the global size control. This option could be installed on all relative components with disconnect option unchecked so that it wouldn't affect any current library filters....
3) All Gradient Components to automatically handle/map any sized Image: No snippets, scrippets, or explanation should be needed for this....
4) User-defined Filter Filing System: Users "need" the ability to create and name their own program-accessable folders for organization/catagorization of their own/modified filters.....with standard drag-and-drop capability.....
likes this.
