it would be nice to have a switch or button or lock where i could tie/lock my control components to the components they are going to, at least if the control is only going to one component. when going to more than one, then, not so much. but a button, that could toggle, would be nice to be able to lock the control phyically to the component so that if you moved the component the control would keep its relative physical location to the component the same.
Selecting both components at the same time is as easy as selecting the one isn't it? [ unless the controller is tangled in with other components I guess ] and selecting the two keeps there relative positioning when moving them smile:)
carl, yes, but why not just tie them together so that you dont even have to do a drag to select? you could just drag the one and the other would already be connected and move with it. in other words, it's just a lazy man's request smile:)
