Joakim
Interaction Designer
One thing I find a bit limiting is that the Blur and Motion Blur filters only handles integers. The difference between Blur radius set to 0 and 1 is quite big and it makes them a rather rough tool.
I would really like to have a little more detailed control by having the filters accept fractional values. Like the Gaussian blur filter in Photoshop where you can set it to values like 0.3 for example.
Joakim
Doh! smile:|
I just found this topic; http://www.filterforge.com/forum/read...=8&TID=181
(I did a search for "blur" before I submitted my initial question to see if anybody else had asked it. I didn't search for just "gaussian" though)
Anyway, let me re-issue the request; Could we have a Control that allows users fractional control over the blur values of a filter?
If you mean a Control component, you can use a simple Slider and limit its range to, say, 0...1 by using Remapping -- this would give you very fine control over the blur radius in the 0...1 range.
Joakim
Ok, I'll try that. Thanks Vladimir!
12 unregistered users.
