Right now it is a bit slow and convoluted to achieve this simple effect...
http://uberzev.googlepages.com/slow.ffxml
Whitedove
Miss Congeniality
Cool! Reminds me of giraffe skin...has anyone thought of trying to make convincing animal skins? Leopard, tiger, jaguar, ocelot, chipmunk (oops) smile:D
Donna
Whitedove
Miss Congeniality
Hey uberzev,
Look what I came across on the 'net...
byRo
an Englishman in Brazil
uberzev, I'm not sure why you put the blur in - but onyXMaster taught ne a trick. Select "Seamless tiling" - the filter works about three times faster.
Also if you put in a Levels component (Black = 0, Gamma = 100, White = 1) between the Blend and Threshold components you'll pick up a few more "Webs".
Rô
onyXMaster
Filter Forge, Inc.
Maybe you should use only a Gamma component (since you're not adjusting black and white points)?
I don't think I know what you mean.
Well, the original goal of the filter was to make a kind of 'baked earth' effect like you see it dry lake beds. I needed the blur to create a realistic height map.
Thanks, works like a charm now. smile:D
byRo suggested to "put in a Levels component (Black = 0, Gamma = 100, White = 1)", and Onyx just said that this would be equivalent to use the Adjustments > Gamma component with the Gamma slider set to 100.
14 unregistered users.
