Hey: know what I'd really like in FF? A component which just samples a color at an X,Y position, and gives you a color. One which doesn't break if the image is non-square, and which doesn't change other things into slow bitmap components.
Something similar to Mike Blackney's Pixel Color http://www.filterforge.com/filters/6791.html
But this technique has the two drawbacks listed above.
Another thing which would be useful would be an average color component. This would be of input green componenets, NOT just of an external image. If this had curve inputs for the X and Y it could be a very flexible component, and would do everything described above. Having curve inputs would allow you to specify exactly which area you are interested in, and could be easily controlled by an Impulse Curve, and a slider for X and Y.
OK, so since a picture is worth 1,000 words, here's a mockup image which better illustrates what I'm trying to propose.
So, I'm not sure if it would be a gray component, or what. So I'm showing it as yellow. The idea is that you control the sample area using curves, and it returns a color (not a bitmap). This makes it very very flexible, and you can use it like a point sample. Like so:
You could also indicate a larger area. (Presumably the 'whole image' would also be the default)
Yes.
ronjonnie
Designer / Artist
Filters: 320
Good Morning Everyone!
I vote YES! smile:ff:
Have a GREAT day! smile:)
Ron
Stay tuned smile;)
11 unregistered users.
