Totte
Ubernerd
Filters: 107
Having the pro version, I can render using all my 16 cores, or I can set FF to use only 1 core.
Feature Request: To have a variable setting on how many cores to use for the pro version, from 1 -> (Max available).
I like to have FF rendering in the background, but running it on all 16 cores kind of bog down the machine pretty much, and using only one core is a little too slow for some filters.
// Totte
meyendlesss
Filters: 32
Check out a program called WinAFC.
You can use it to see affinity to whatever cores you want to use.
There are tutorials out there to help you set it up.
If you have trouble post back and I'll try to help.
Would be nice to see that feature added to FF though.
Totte
Ubernerd
Filters: 107
Hello,
I run Mac OS X, where you cannot use SetAffinity() to lock processes to a certain Core, which is good, as that usually ends up where several Apps locks to the same core having that core sweating to death while the others are unemployed, seen that too many time on Win32.
And, it should be controllable by the app itself, just how many threads to spawn. By SetAffinity(), you lock the threads to the same core(s), but it will still be 16 threads spawned and running on 8 cores, which will be about half as fast as 8 threads running on 8 cores, if you consider context switching overhead, and choking.
(Been doing threaded programming for the past 12 years... )
meyendlesss
Filters: 32
Guess it depends on what you're doing and what software you use.
I'm running Vista 64bit.
Usually only set affinity for folding.
Don't bother when using FF as I want all the power my little i7 has rendering for me.
Totte, unfortunately no plans to add this in the near future.
