tonys
Not sure if needed in PhotoShop becaue I don't use it - but in other programs and in stand-alone mode, an eye-dropper in the color picker/s under the Settings tab would be very useful.
I often want to sample colours from the original image.
Tony
Apples
Filters: 37
After reading this I remembered that I often want to use a same color.
When I make a filter and arrive at the last stage, I connect the color inputs, but I never get the same color as I already had.
So I love to have a save color option. smile:)
May The Forge Be With You
You can copy & paste colors.
Apples
Filters: 37
Ah smile:blush:
Can you tell me how to copy a color from a component to a controller?
Because the ctrl C & V doesn't work for me.
Right click on the color in the options (the teal color for example). You should see a Copy Color and a Paste Color. smile:)
Apples
Filters: 37
Thanks Betis,
I see the copy color and paste color.
But I'm afraid that I'm doing something wrong because I can't copy from the component to the controller.
I did manage to copy the controller itself.
Very embarrassed. smile:blush:
hi apple,
it is as betis said. just remember that you also have to right click over where you wish to paste in order to paste the color into the new component.
tigerAspect
Filters: 9
1: Right Click on the color you wish to copy, and click on Copy Color.
2: Select the control node.
3: Right click on the color and click Paste Color.
4: Voila!
Apples
Filters: 37
Thank you all!
I realize what went wrong, I tried to paste in the selected floating color controller instead of the info box at the left.
I'm really pleased. smile:ff:
Wow. I never knew this. I always used to copy the HSB numbers or eyeball it. What else can I right-click? smile:D
12 unregistered users.
