now, this is probably similar to some other requests for features and perhaps it's even been requested before, not sure. but, what i was thinking of was having multiple inputs, at first, like importing more than one image into the same filter and then being able to blend those and work with those together. and that got me thinking about photoshop and paint shop pro and layers. you can do that sort of thing in those programs quite easily and use blend modes and so on to combine them and play around with them and so on. so, why not in FF? i could see having several images at once imported into the same filter, each on its own leg but with the ability to combine legs and blend mode those legs and so forth. in fact, you could use any of the bit map components to combine such legs and images. i think it would be a worthy addition.
i could also see having with this, preview window, in the editor that the user specified, and more than one. i mean, why not have three preview windows in the editor or more, if you wanted and had the computing capacity to pull it off? and you, the user would set these as you wanted, to any given component.
Octop
I'm not calamari yet.
I'm with you on this. It would speed up workflow by about 2500%.
How about it FilterForge team?
