I'm not so sure about the inner workings of Filter Forge, but I think it would be nice if there was a compile node that turned an output into a bitmap, you could then do other bitmap functions such as Blur, taken from not an algorithm, but a pure image. Otherwise you have to blur layers upon layers of outputs. Yes? smile:|
saurabhgayali
Saurabh Gayali
Filters: 84
yes
its a good idea
I usually use blend or multiple blend for this
but results are not such what is required.
+5
All bitmap-based components (Blur, Sharpen, High-Pass, Median, etc.) create an internal bitmap before processing:
http://www.filterforge.com/more/help/...nents.html
Very interesting link. Informative as well. Do Blurs at a radius of 0 still output a bitmap? Or do they have a sort of switch that says 'at 0, do nothing'?
Yes. At 0 they'll just pass the samples through.
Do you mean the bitmap samples?
No. I mean procedural samples, bitmap is not created in this case.
Oh, excellent.
