That way we could generate our own environments which is usefull for achieving certain effects.
onyXMaster
Filter Forge, Inc.
The only way to use your own environment is to import it using Tools -> HDRI import. It's a lengthy process (taking tens of minutes for medium-sized images), requires a specially prepared input image (HDRI in latitude/longitude format) and produces a large output (around 2 MB for 400x200 input image).
onyXMaster
Filter Forge, Inc.
A minor notice -- custom environments may be used to some degree (error is around 7% on a 1024x1024 image with hemisphere and a 400x200 input environment and is invisible to an untraied eye) without special preparation (latitude/longitude format still required) if the "reflection blur" is locked to zero.
14 unregistered users.
