Lucato
Ideas for green Components...
a) REPEAT/EDIT: Sometimes I have the need of repeating a whole subtree but with some different values in some controls. So, here goes a new Component suggestion: • How would It looks like? The green 'Repeat/Edit' component would have thumbnail, an output, one green 'Input' called 'Subtree' and one* gray 'Input' called 'Edit 1'*. • What does it sand for? You would repeat any subtree without needing to repeat all components and with the advantage of getting to exchange some controls values. • How It works? Let's suppose you need to use 2 identical subtrees but with some different values in some controls. So, you would connect your subtree into the green 'Repeat/Edit' component through the 'Subtree' green input. Now let's suppose you want that the repeated subtree has a different color**, than you get the output in the Color Control from the original subtree and connect It too into the gray 'Edit 1'*. Now you would edit this Control with a new value. The 'Repeat/Edit' thumbnail will show the modifications and the output will be as the thumbnail. Something like that. * These would have more than one. ** Any Control would be edited. b) (Coming soon). |
| Posted: June 18, 2006 8:51 am | ||||
Administrator |
I think all this fits into the idea of Groups/Subroutines/Procedures. We will start working on them as soon as we have time -- this task is on high-priority.
| Posted: June 19, 2006 7:35 am | ||||
Lucato
Thanks FF team. Ideas for green Components... b) Tiles Component (update): I'm not sure if it is possible, but FF team would make a "little" update in Tiles Component. It would have an option to act as Hexagonal. I mean, In the Tiles Component if you make corners 100 / repeat 3 and look at the vertical spaces between circles and horizontal spaces, they are different from each other. They don't have the same distances. Look into Uber filter to see how hexagonal superpose the lines. c) (Coming soon). |
| Posted: June 21, 2006 3:03 pm | ||||
Lucato
c) Combine: The Combine component would be one for the green component and other for blue component (curve). The component has inputs Source A, Source B and Operation. Where the operation input has 4 oparations: 'Add', 'Subtract', 'Intersect' and 'Exclude'. See image attached to see each result. |
| Posted: June 27, 2006 5:23 am | ||||
Administrator |
Lucato, the Combine for curves you suggested above is impossible to implement -- it treats curves as 2D images, but curves aren't images, curves are function graphs, and you can't have a butterfly-shaped function graph.
As for Add/Subtract for Map components, we'll be adding them (and some more) in the next or a subsequent update. |
| Posted: June 29, 2006 3:12 am | ||||
Administrator |
I'm glad you put these quotes around "little" |
| Posted: June 29, 2006 3:15 am | ||||
Lucato
I see, as I'm a lay in the subject, for me they were just planar images. Thanks for the info. |
| Posted: June 30, 2006 4:35 am | ||||
Lucato
Yup, I could imagine that it wouldn't be so easy. |
| Posted: June 30, 2006 4:40 am | ||||
Lucato
d) Lighting: It would be very cool if we could have a Lighting green component as the lighting tab where we would control things trhough slider even the orientation. Besides that we would have an option to make the tab Lighting on/off for the filter. I mean, let's supposse I've created a filter that I want users control lighting only through sliders I've created instead off through the tab, so I would hide the tab (off). The component would be something like that: |
| Posted: March 12, 2007 9:57 am | ||||
Lucato
e) Assemble RGB: in this component besides the sliders R, G and B, it would have the color option (Color picker), but it won't generate the final slider in the filters control. This color picker is just to make easier and faster to select a color instead of using the RGB values. f) Coming soon... |
| Posted: March 22, 2008 7:37 am | ||||
Lucato
f) Result END/CONTINUE: I'm not sure if it would be possible, but I'd like to have an option in the Result component where I would inform it if it is the END or not. If I mark as END, it will show the FILTER CONTROLS, if not marked as END it would add an output to continue adding other components. Several times I needed to continue a filter from the results and didn't get the same result without passing trough the result component if you know what I mean. g) Coming soon... |
| Posted: September 26, 2008 1:25 pm | ||||
Lucato
Ideas for blue Components...
g) Combo Curve: FF would have one componente as a COMBO CURVE with all curves and settings. So, when I use this COMBO CURVE, in the final filter at filter controls the user will have a dropdown list with all curves names and when picking one from the dropdown list, it will show all setting from it. These settings names can be edited by the filter creator at the filter editor not by using 'controls', but just renaming the settings in its own curve combo component. This combo would have a check box to selec publish or not publish, so if a curve into this combo is set as not publish, it won't show in that dropdown list. h) Coming soon... |
| Posted: June 18, 2009 8:23 am | ||||
