Sometimes when I look for the correct value of a component variable I just attach a remapped slider and wiggle it untill I have the value I like. Then I remember the value, pull off the slider, and manually type in the remembered value.
It would come in handy if the value stays the same when you pull off the control (especially for decimal color values, which can't be picked with a color picker).
33 unregistered users.
