Right now... the 'existing filter' status is saved in the xml of the filter itself.
Since the upload dialog requires authenticiation anyway, maybe it is better to retreive the list of uploaded filters from the server instead of checking the 'my filters' folder.
I've had the following problems because of this....
Sometimes I have multiple versions of a filter, upload one, improve other versions, delete older (uploaded) versions, try to upload new versions but they will only upload as brand-new filter.
or...
I sometimes upload filters from work, sometimes from home... so sometimes when uploaded at work... and then a changed- earlier version at home will only upload as brand-new filter.
gr...
Ron
Top
Filter Forge, Inc.
Sjeiti, currently the list of accepted to the Filter Library (not submitted) filters getted from server every time you run Submit Wizard (update filter option). No status is saved to filter's XML.
Currently, you can submit updates to you filters which already accepted to the Filter Library only. You'll received e-mail each time filter (or it's update) accepted to Filter Library.
Is it?... oh ok... sorry then...
(I wonder howcome I had these problems then...)
gr...
Ron
Ah wait, the reason is probably the difference between -submitted- and -accepted- : I was too fast in submitting an update.
Since you say 'currently', are there any plans on changing this in the future?
gr...
Ron
