So, I use FF for 3d textures. The normal map render map in particular was a HUGE selling point for me.
However, using it, I wish there was a way to render to disk all the appropriate maps in one fell swoop, and not map by map, by hand. I just want to select a folder, pick the maps, and have it render them. That way you can do it in large quantities, and save on all the repetition. (Something like the interface for Vue 6 infinite's multi-channel rendering, maybe.)
Also, along the same lines, it would be good to be able to give your files proper naming conventions. If you're making a lot of textures, it's a hassle to hand-name everything. I'd much rather be able to name a folder, tell it that bump maps always get an "_b", spec maps always get a "_s" suffix, etc. and just let it render out. (Pshop's batch rename filter is pretty good UI-wise.)
Anyway, great program!
Dang, this has also been previously suggested, I just missed it. LINK
Another vote of support!
No worries, the more people that politely suggest things (repeatedly, and from different people requesting those same things), the more likely that it gets put in V2. smile:D
