James
James
Filters: 46
I was just thinking it would be cool if with the switch module rather than having a 12 source setup which not have an adjustable version, so it would start with 2 ports, 1 would labelled Empty and the other Selector. Then if you added a source it would say Source1 and add a new Empty port, So basically you could use just the amount you need so you could have say 3 sources and there would be a empty input if you wished to add more and if you need more than 12 it would just keep going resizing the module the more inputs added smile:)
James
James
Filters: 46
Also another idea for switches would be to be able to name the inputs to anything you like, then at some point if a drop down controls added it could automatically use these names in it's list.
Ah, I missed this one......great ideas!!! smile:) smile:) smile:)
James
James
Filters: 46
NP smile:D
Yeah I want a Drop down control too. The intSlider is a bit of a black box in most cases.
