here's a thought; since it's possible to simply change a .jpg to an .exr by simply changing the extension in windows explorer and that that then makes it possible to import this former, but still really a .jpg into FF as a lighting environment, why not just allow a direct import of .jpg's (and maybe even other file formats) into the HDRI import function? seems a simple enough thing.
onyXMaster
Filter Forge, Inc.
Well, it was more a term-oriented decision, since JPEG's are not HDRIs, so importing them as HDRIs sounds wrong. Maybe HDRI Import should be renamed to Lighting Environment import or whatever. If it is renamed, I think accepting JPEG's, BMP's and other LDR images may be fine.
yeah, that sounds about right. just seemed a bit silly to me to have to change a .jpg to .exr before i could import it. so, if it's a semantics thing, please smile:)
also, what is an 'LDR' image? the only ldr i'm familiar with is light dependent resistor.
onyXMaster
Filter Forge, Inc.
LDR is Low Dynamic Range (as opposed to High Dynamic Range in HDR) smile:)
ah, ok. thanks smile:)
