hadnt noticed this one before, but there's no angle control in the cell noise component. seems odd. if you have a stretch control, which you do, then i would think it natural to then have an angle control so you could rotate that effect to different angles.
yes, i know there's a 'vertical stretch' and that's good, but a full angle control would be great.
In fact, there are no angle controls on any of the worley noise components.
Take a close look at what happens with a perlin noise on seamless tiling when you drag the angle slider. My guess is that this kind of edge blending is not possible with worley noises...
hmmm, so, the solution, you think, would be an angle rotate component that you'd plug in after a worley?
