Deskar
Greetings,
I have two ideas to suggest for the next version. I think it has already been discussed the extreme need of counting with more mathematical flexibility. The curve formulas could be input by the user, that would be fantastic and would improve FF's features in a great way. Another characteristic that would empower the program would be a cellular automata component. The ability to create patterns and modify components would become terribly big. Cellular automata are pretty fast to compute and their aesthetics are both varied and eye-catching. They're used in several common filters, Blur being one of them and High Pass as well, if I'm not mistaken. It would be great if you could add the possibility to create custom cellular automata building rules. Both suggestions have a rather simple mathematical complexity and would increase the program's potential way beyond other filter-maker programs. New users could avoid complications directly by not using the most complex characteristics of these new components. Advanced users would be in heaven. Here are some links about cellular automata: Examples of the graphic potentiality of CA. http://www.cs.sjsu.edu/faculty/rucker...mples.html Software to generate the game of life (made with CA) http://psoup.math.wisc.edu/Life32.html Articles about the subject , by Stephen Wolfram (genius of geniuses). http://www.stephenwolfram.com/publica...ticles/ca/ "A New Kind of Science" by Stephen Wolfram. Free online book that collects ten years of works with CA. http://www.wolframscience.com/nksonline/toc.html Various links http://demonstrations.wolfram.com/2DT...rAutomata/ http://images.google.com.ar/images?sv...C3%A1genes To bit or not to bit |
| Posted: August 31, 2007 1:43 am | ||
| Posted: August 31, 2007 9:48 am | ||
yeah, that is cool....
| Posted: August 31, 2007 4:49 pm | ||
i agree it's cool. i remember this from WAY back in my computing days, but i'm at a loss here. how would you translate or implement this concept as something usable in FF?
| Posted: August 31, 2007 6:54 pm | ||
| Posted: September 1, 2007 5:51 am | ||
Deskar
| Posted: September 1, 2007 6:15 am | ||
Deskar
| Posted: September 1, 2007 6:47 am | ||
Deskar
| Posted: September 1, 2007 6:52 am | ||
Deskar
Diffusion-limited aggregation is a type of Automata Cellular.
Lightning bolts, rivers, veins, electrophoretic process... http://fd.alife.co.uk/dla/ ![]() To bit or not to bit |
| Posted: September 1, 2007 7:34 am | ||
Deskar
Th image of the Giraffe pattern may be was made with voronoi... Its cool too.
| Posted: September 1, 2007 7:36 am | ||
Deskar
Fractal Drainage Patterns. A lot of fractals were generated by CA.
| Posted: September 1, 2007 7:44 am | ||
Deskar
| Posted: September 1, 2007 7:45 am | ||
Deskar
More Fractal Drainage Patterns.
| Posted: September 1, 2007 7:49 am | ||
Deskar
Generated online and they render very fast. http://fd.alife.co.uk/model/ ![]() To bit or not to bit |
| Posted: September 1, 2007 7:56 am | ||
Deskar
More useful links.
http://cell-auto.com/ http://cafaq.com/soft/index.php http://axxon.com.ar/zap/278/c-Zapping0278.htm (in spanish but with a lot of images) Deskar (Diego) To bit or not to bit |
| Posted: September 1, 2007 7:58 am | ||
ok, i think i get where you're going with this for FF...at least some of it. man, animate this in FF and whoa!
| Posted: September 1, 2007 10:40 am | ||
Deskar
I wonder if Vladimir or someone from the staff is reading this.
What do they think? Deskar To bit or not to bit |
| Posted: September 3, 2007 9:24 am | ||
onyXMaster
Posts: 350 |
I'm not Vladimir, but I think I will suffice, since there was time when I read some Conway's books.
CAs operate with discrete cells, performing simulation step-by-step (generations in terms of "The Game of Life"). Filter Forge operates with function samples only. Of course, there are exceptions to this rule (bitmap-based components like Blur), so I do not rule out the possibility of emulating small-generation CAs, but I seriously doubt that CAs will make it into next major versions of Filter Forge. |
| Posted: September 3, 2007 10:14 am | ||
