Lucato
Ok, let me be a little organized, let me place all here and the future ones too.
Ideas for Filter Editor a) Full screen preview of the work area by clicking on TAB key. By clicking againg switch to the normal view. b) When using editor, in the setting tab would exist a way where we would click twice on the slider tittle, and it would locate (jump/send us) to the control on the work area and select it. Or... we would right click on the work area and get a context menu with "Controls >" and show all controls names we've setted. So, from this context we would select the desired one and the work area jump to the selector. (FF team, if you want, you can delete the previous post like this item) c) (Coming soon) |
| Posted: June 4, 2006 8:35 am | ||||||||||||
Nice ideas...
I'd rather have the full screen preview work with the F key ala photoshop. |
| Posted: June 4, 2006 8:49 am | ||||||||||||
Lucato
Thanks Uber, I've never used F key before, just by clicking. hehehe.
| Posted: June 6, 2006 6:36 am | ||||||||||||
Lucato
c) Components Outputs (Green arrow on the left of a component): I frequently use the Components Outputs to conect more than one component/node. So, sometimes I spread the connectios to a lot of components/nodes. It would be very useful if we get to hold and drag "the big green arrow" (output) with a key/mouse* to place in another component/node without losing all spread and conected connections.
* Would be holding Shift+Click or holding right click. |
| Posted: June 6, 2006 6:37 am | ||||||||||||
Lucato
d) Still talking about components, the Result Component would be dived. I mean, we would have a new Component Filter Type and we would use controls to pick Surface, Simple Filter, and so on. So, with the Filter Type Component we would continue build the filter. I would add a "Blend" after that and so on.
e) Looked to: When we unlock the Component preview, It would by default go look the Result Component. f) (coming soon) |
| Posted: June 6, 2006 6:59 am | ||||||||||||
Administrator |
You mean the tree area?
Cool -- I'm adding this to our list!
I agree -- F is better since Tab is already used in keyboard navigation.
Just to confirm -- you want to be able to replace component without losing its connections? |
| Posted: June 6, 2006 8:10 am | ||||||||||||
Administrator |
This is technically difficult at the moment, I wouldn't expect this anytime soon.
I'm not sure I understand what you mean -- could you please give more details? |
| Posted: June 6, 2006 8:12 am | ||||||||||||
Lucato
I think so. I don't know the right name, but I think it's Workspace like this: . So, yup, a full screen preview of the work area by clicking on F or TAB or whe best key would be very welcome.
Thanks, I'm glad you liked. It will help us a lot.
Oh man, I told you my Language Barrier sometimes gives me a hard time. You got the meaning in one phrase. Hehehe. Yup, without losing the output connections. Vlad, just came another idea to my mind how it would work instead of dragging the "Big Greend arrow" to another Componente, maybe It would work by dragging the new component over the old one. I think this second option is better than the 1st one.
Ok, let's leave the Filter Type Component for the next future.
Ok, I'll try again. Fast ans long way. Fast try: Click twice on a node to preview the rendered node (Eye). Now click twice again to remove the eye. The idea was that the eye would go to the result node automatically (as I had clicked twice on the result without going to the result node and clicking over it.). The preview become a "looked to Result". Long try: Vlad, in the Filter Editor when we click twice on a node we get that small eye on the right top of the node and this node is rendered in the preview window (left top). Now a days if I click twice again over a Looked node, It will "Unlock" the preview, but will remain the rendered image in the preview window and my suggestion was once we unlock a node, it would lock automatically the Result node. Did I get to explain what I wanted? A hug. |
| Posted: June 6, 2006 9:17 am | ||||||||||||
Quasimondo
I like the dragging of the big output arrow better - I fear that if it gets triggered when dragging a component over another one this could lead to cases where you accidentally replace the a component when just moving things around on the workspace. Or with "new component" you want to say that the replacement only occurs when one drags a component from the list to the workspace? |
| Posted: June 6, 2006 11:06 am | ||||||||||||
Lucato
Hi Quasi,
What about use Ctrl+Z (Undo)? Heheheh. Just kidding. Well, if you drag on the empty workspace area it will be a New Component, but if you drag over the one that is already in the workspace, it will change to the dragger/release component. It will keep all output connections, but in some cases you will lose the inputs connections once nor all components has the same structure. Anyway it will be very useful if implanted. Our suggestions most of the times are based in our needs. Cheers. |
| Posted: June 6, 2006 6:56 pm | ||||||||||||
Lucato
Ideas for Filter Editor ...
f) Pointer area selector: It would be interesting to get to hold SHIFT+LMC (Left Mouse Click) on a empty area of the workspace and select an area. When you release the LMC It selects all Components that are into this selected area (See image attached). By pressing SPCACE BAR would unselect all components. g) (coming soon) |
| Posted: June 9, 2006 5:16 am | ||||||||||||
Administrator |
Hmmm... interesting. We dropped the marquee selector in favor of always-accessible Pan (it is a more frequently-used operation than the multi-selection). Shift is currently used to select multiple components, but I think it is possible to leave Shift-LMB-click as it is, and implement the marquee selector on Shift-LMB-drag. We'll definitely consider this for inclusion -- thank you for the idea. |
| Posted: June 9, 2006 7:03 am | ||||||||||||
Lucato
Marquee Selector, that's the name!!! It sounds much better than Pointer area selector. Hehehe. Hey Vlad, I agree with you that Pan we use much more, so, keep this way. I think the Marquee Selector would also use the same Shift+LMB+Click once that the we will click on the empty area in the workspace. So, when I hold Shift over a empty workspace area, It would change the hand icon to pointer icon. Once It's a pointer, keep holding shift and just click and drag to select the marquee area. After release and still using the same the same Shift+LMB+Click, but now over a component, I would select some extra components that I didn't get in the selected marquee area. Anyway, you guys will see what combination is better. Thansk for considering this for inclusion and you're very welcome. |
| Posted: June 9, 2006 7:35 am | ||||||||||||
Lucato
Ideas for Filter Editor...
g) Organizing Components: When creating filters we use to use some Components more often, so the suggestion is to create a way allow us to reorder the component list by dragging the components (See image attached). Maybe just in the 'ALL' category or better, get to reaorder all categories. h) (coming soon) |
| Posted: June 9, 2006 5:55 pm | ||||||||||||
Lucato
| Posted: June 15, 2006 6:48 am | ||||||||||||
Administrator |
Agreed, this would be very nice. |
| Posted: June 15, 2006 9:18 am | ||||||||||||
Cool idea. Personally, I would be happy if I had a customizable 'Favorites' category that I could just drag&drop components into. Navigating through the categories can be a bit of a drag sometimes.
This is a must-have! --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: June 15, 2006 9:37 am | ||||||||||||
Administrator |
The problem is that I'd like to kill this panel completely -- it eats up too much space. I'm thinking about replacing it with something that doesn't sit on the screen permanently, for example a dropdown menu. |
| Posted: June 15, 2006 9:44 am | ||||||||||||
Lucato
Good idea too Crapa. |
| Posted: June 15, 2006 12:13 pm | ||||||||||||
Lucato
Ok, here goes two options Vlad (Vertical and Horizontal): 1) Vertical: It would continue with the button Component on the top to hide/show, but you would take out the names and just show the icons. The names would be shown when you mouse over. See the image attached of the vertical version. Will eat a little less. |
| Posted: June 15, 2006 12:14 pm | ||||||||||||
Lucato
2) Horizontal version: It would continue with the button Component on the top to hide/show. On the left a drop down list to pick the categories. Below It shows the name of the Components when mouseover on the small icons in the horizontal scroll bar. The icons are smaller than actual ones. (See the image attached)
I vote for the horizontal #2. |
| Posted: June 15, 2006 12:23 pm | ||||||||||||
DrEvil
Hi people first post and im not sure if anybody has said this...but instead of a program defined keystroke..... a user one make everbody happy at the click o the button
Please sir can i have some MORE ! |
| Posted: June 15, 2006 1:39 pm | ||||||||||||
Lucato
I'm sorry, maybe It's my Language barrier, but I didn't get that DrEvil. What was the fun? Does it have to be with the thread/topic in question? Maybe byRo can traslate that for me. |
| Posted: June 15, 2006 2:49 pm | ||||||||||||
byRo
I think DrEvil is talking about inserting components with some user-defined key sequences. Well, at least I hope so because that's something I'd like to see. Suppose you are constructing a filter and you need one off the more common components, like a Blend, or a Profile Gradient. Instead of opening the component area, navigating and dragging - wouldn't it be nice to just press the <B> key for the Blend (or <P> for the Profile Gradient). (actually I just copy one that's already in use) Rô _________________________________
My favourite question is "Why?". My second favourite is "Why not?" |
| Posted: June 15, 2006 4:17 pm | ||||||||||||
almost any more i use the copy and paste to add new components. so, defined keys to me gets to be an annoyance because you have to start remembering control-shift-alt-d-plus xyz if it's a tuesday and invert the whole thing if it's an odd month of the year. ok, maybe that's a bit of an exaggeration. the simpler way is to right click on the component and have a 'copy-paste' item as one item instead of having to hit copy and then paste.
yeah, i know, that only works if you've already got one item open of that kind. still, it's a nice shortcut. to get a completely new component, small icons in a toolbar works best once you get to know what things do. being able to dock that toolbar where you want or hide it altogether is a plus also. craig If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 15, 2006 4:36 pm | ||||||||||||
How sweet would it be if the horizontal menu worked like the Dock in OSX? Example... http://jrgraphix.net/research/flash-dock-mx-2004.php |
| Posted: June 15, 2006 7:15 pm | ||||||||||||
Lucato
I agree that It's cool Uber, but just if you use few times. I guess I would get very dizzy by picking a lot of different Components while creating an effect/texture. |
| Posted: June 15, 2006 7:22 pm | ||||||||||||
Lucato
Ok, f) checked.
Thanks FF team for adding in a better way the suggestion f) in the version 1.004. ("the Editor now supports marquee selection that allows to quickly select multiple components, which makes editing complex filters much easier") You can also use Shift or Control to select/unselect more/less components inside/outside the marquee selection. Thanks a lot ff team! |
| Posted: October 26, 2006 12:24 pm | ||||||||||||
Yeah, this works like a charm now!
Next up: Large Preview please! --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: October 26, 2006 3:47 pm | ||||||||||||
Lucato
i) I'd like to disconnect an input in a component and while holding this disconnected line/triangle I would see the difference/results in the node. So, if I don't like I can plug again without loosing the tail/line/triangle. Now a days I just get to see the difference when I unconnect and release the the line/triangle. Sometimes the nodes are far away, and If I just want to disconnect to see the difference results, I lose the tail and I need to go back all the way to pick and bring back the connection. j) As I said above, some nodes are far away, it would be cool to have a way to disconnect an input by holding shift and it would scroll/move automatically the screen (workspace) to the componente where this connection comes from and mark it as yellow (selected). k) coming soon... |
| Posted: December 5, 2007 3:49 am | ||||||||||||
You can alway just use the undo to go back to the original state
| Posted: December 5, 2007 5:25 am | ||||||||||||
Lucato
| Posted: December 5, 2007 12:18 pm | ||||||||||||
Lucato
k) It would be interesting to get to load a new image into the image node while into editor mode. So, I would test another image without needing to save the filter, go out the editor, change the image and come back to the editor. l) coming soon... |
| Posted: December 5, 2007 12:20 pm | ||||||||||||
Lucato
l) Each node would have a little buttons on the bottom (green and grey) where when you press it, it create/expand all controls (sliders/checkbox/color...) for this node making them connected and with the original names. If you click on green button will create for all green connections and grey for grey connections. m) coming soon... |
| Posted: December 7, 2007 4:27 pm | ||||||||||||
| James |
Maybe multi point wires, which you can curve to make the module structures look nice
holding control or alt (or something) when hovering over a wire gives you the option to delete the wire +1 for the image changing idea, it gets annoying having to save all the details always imo Turn off previews or have it so you can change the res for them, so you could have a basic set for the earlier modules then a high quality preview of the final to speed up development on pc's which don't go too fast with FF, like thumbnail size in a way does but for each individual module, then also have the option to set all the same so you could quickly set all to low then go to the prieview and set it to high etc for a quick way of doing it. The abillity to hide/minimize certain things would be nice if you needed to see more of the structure and could quickly click an arrow to hide the left side etc How about a duplicate feature, like copy paste however keeps all wires connections, not essential but speeds up workflow sometimes The abbility to un dock the preview, so we could for instance un dock it drag to the center of the screen then enlarge the size rather than having it set and having to save and go to the main preview to see the larger version. And of course what i keep asking for Thats it right now, sorry if any of these have already been mentioned |
| Posted: December 8, 2007 8:02 pm | ||||||||||||
Lucato
m) Now a days when se select a node we get a yellow selection color. It would be cool if after selecting a node, all connected nodes to this node (only 1st outputs) would get a different selected color and the connected nodes for inputs would also get another selection color; n) We would have a kind of "find next". So, if I select the node TILES, I would press "N" and it would take me to the next TILES node; o) As James suggested above the grouping feature would be amazing. I mean, group all into one GROUP NODE where we could give it a name. If it isn't possible, maybe a way to draw a box, like when we use a marquee tool, and after creating it, it would get a tab on its left top where we would type a group name; p) Coming soon... |
| Posted: February 23, 2008 6:42 pm | ||||||||||||
Lucato
p) In the pop-up "Order of controls" it would be cool if FF would allow us to move up/down more than one iten at once. I would select more than one iten by holding Ctrl (alternate) or Shift (range) to get to move them up or down; q) Coming soon... |
| Posted: March 10, 2008 8:36 am | ||||||||||||
Lucato
q) Talking about "Order of Controls" in item p) above, it would be cool if in this pop-up we had also a button "Add line". So, if we click on it, it would add in the order list the word "SEPARATOR" or even a line "___________" and we would get to move up/down. I mean, a way to add division lines (separators) whenever we want to and get to order them. So, in the settings tab, it would show these separators. Well something like that; r) Coming soon... |
| Posted: March 13, 2008 6:51 am | ||||||||||||
Lucato
r) When I open the Filter Editor by clicking the [Filter Editor...] button from the main window, I'd like that it opened the preset I was selected in the main window. Now a days it opens the 1st preset and not the selected preset. So, after opening the Editor window I need to pick again the preset I want. s) Coming soon... |
| Posted: September 24, 2008 4:28 pm | ||||||||||||
Lucato
s) The same way we have the 'Marquee Selector' in the editor, I'd like to request a Loupe(+) with Marquee Selector. So, when I select an area it will zoom 100% this area selected. Now a days I need to click several times to get to achieve 100% the area I want. t) Coming soon... |
| Posted: September 26, 2008 12:40 pm | ||||||||||||
sariimi
Posts: 1 |
Hi!
It would be great if one could map the scale option (grey at the moment) of a noise component with an other green component. May it be possible? |
| Posted: October 11, 2008 11:48 am | ||||||||||||
Lucato
t) Floating preview/properties and components bar As a three monitor user I'd like to drag the preview, properties and components bar on the other monitor and just leave the workspace in one monitor when editing a filter. This way preview, properties and components bar would be resizeble to get bigger preview or adjust the stuffs in other sizes/positions; u) Coming soon... |
| Posted: June 18, 2009 8:33 am | ||||||||||||
