Lucato
FF addicted
Hi Vlad, maybe to add in your to do list. smile:)
While creating a filter effect, came a need and a suggestion in my mind. It would be interesting if in the Switch node we would give a name for each source# (1,2,3,4 and 5) and its title. In the setting tab It would show as a drop down list (see attached image). So, we would give a name for each variation and also for the title of the switch. Users would pick a name instead picking numbers (1-5). Actually, It depends of the needs, so, if we could have both to choose dropdown list or slide numbers, It would be amazing! smile;)
Yes and I have to have this, nice mockup BTW. smile:D
Lucato
FF addicted
Thanks Uber, let's pray together. hehehe. smile;)
byRo
an Englishman in Brazil
Kudos, for the semi-transparency! smile:D
Rô
If I add this to our plans, the programmers will kill me smile:)
The thing you're talking about is called a List control, and it has List-to-Anything remappers which are VERY hard to implement, debug and make usable. We had to drop them from our plans, because it would take too much time which we couldn't afford -- 3.5 years is already too long for a Photoshop plugin smile:)
