PogS
Filters: 44
Hi all
Here is the list of improvements I'd like you to implement :
Editor
File
> Revert Filter (to last saved state)
> Import Filter Tree (import tree into
Control components
- slider and intslider : add minimum value
- intslider : max value number improve beyond 1000
Filter Library
allow the ability to define anti aliasing presets
try 'contol-z'. and if this isnt what you meant, why would you need to 'revert to last saved state? you've already got it saved; just re-load it.
you can copy and paste whole tree structures now, including the connecting lines. also, i believe there is an ungrade coming somewhere down the line that will allow whole trees as components you could import and export.
i really dont see the need for a value over 1000 on int sliders. could you specify why you need this?
PogS
Filters: 44
The revert would be nice as you have to quit the editor to reload the filter.
Importing would be a lot simplier as your way compels you to quit the editor load the other filter quit reopen your filter. That is a lot of operations...
ok, i see.
Excellent ideas!!! I can't begin to count the number of times I "knee-jerked" saved, scrambled the primary effect I was working on, and then had to go back and dig it out again.....not to mention ruining all the presets.....which has taught me not to waste my time making more than a few presets until totally finished with the filter.....
PogS
Filters: 44
Also I'd like th Editor interface to be more customizable and to be modified to free more working space such as the following :
righr click display image to view in full size :
I would also like to be able from within the editor to toggle on and off the seamlessness feature. It is really annoying to work on something to realize after saving it is not possible to make it seamless.
PogS -- yes, we've played with this idea. At the moment, I can't say I'm 100% satisfied with how it feels.
You already can -- select the Filter Controls thingy under the Result component, and turn Seamless Tiling off in the properties.
72 unregistered users.
