buck
buck
It would be nice to have nodes that could be minimized (shade on linux) when not needed.
Softimage XSI has a very nice implementation of this. Attached image.
Also grouping into a container would be great. Fusion 5 does this nicely.
Buck -- we had the vertical collapse feature in our earlier prototypes, but scrapped it later, because it wasn't very helpful -- the width is a bigger problem than the height.
Hopefully, the Tree Zoom feature will reduce the need for minimization.
P.S. Personally, I don't like the way it is done in XSI (the tree-state switch, full/partial/minimized).
We're considering this, but don't expect that anytime soon.
buck
buck
How so?
Imo, its nice because you can leave them all collapsed and when you drag a connection over the node and let go it gives you a quick popup of all options you can plug it into. Select from the list and it plugs it in.
buck wrote:
How so?
Personal taste I guess smile:)
15 unregistered users.
