socalboy
Filters: 5
Would there be a way from within the filter to invert the selection you made in Photoshop? For example, you select something in photoshop, go to the filter, while in there, you realize you should have inverted it to get the area you wanted. instead of getting out of the filter, then inverting the selection, then going back into the filter, it would be nive to just be able to invert the selection from withing the filter.
Matt
Plug the Selection component into Invert smile;) You can find the Invert component in Adjustments.
