the transparency checkboard image is usually fine, the little gray and white checkerboard thing. but, sometimes it's in the way and i want a solid white, black or gray.
would it be possible to add those options to the options list? i want this for both the editor and the GUI.
As a workaround, you can add a Blend with the color or pattern you need as the background, then delete it later.
ok, that works. not quite as elegant as being incorporated into FF, but by adding a switch and checkbox to the switch, i can swap back and forth and see the checkerboard or not.
this came up as a result of my 'soap bubbles' filter where i have a semi-transparent on a complete transparent and that checkboard was giving me a skewed view of the effect.
thanks, vlad smile:)
56 unregistered users.
