ronviers
I would like switches to map remap data from control inputs to outputs. Also it would be nice if switches would daisy chain.
@ronviers |
| Posted: May 2, 2007 9:00 am | ||
Administrator |
Hmmm... not sure what you mean here. Could you please elaborate?
| Posted: May 4, 2007 11:11 am | ||
ronviers
Hi Vladimir,
If you skip down to about the last half of this thread: http://www.filterforge.com/forum/read...0&TID=2111 you will see it discussed in some context. I want to add that for this feature to be truly useful it would need to be implemented with a mod that made the control component’s visibility to the user selectable inside the filter, i.e. a checkbox on each control that determines its accessibility to the user. I think the idea of daisy chaining the switches is probably pretty obvious. Thanks, Ron BTW, you have 13 days to finish this and make it available or I will not be able to use it @ronviers |
| Posted: May 4, 2007 3:52 pm | ||
163 unregistered users.
