James
James
Filters: 46
How about adding a slider range checkbox and if ticked then 2 value boxes appear min and max, i just thought of this while using the variation feature as big changes had a dramatic effect on the outcome and i wanted just slight variations each time, this would limit the variations which in some cases is a good thing imo with certain filters. And of course if someone downloaded a filter with these applied and wanted to make heavy variations then they could just edit the filter and untick the option.
ssamm
Filters: 21
In case you don't yet know about these features:
You can use the "Use Remapping" on the sliders (in the editor) to create a minimum and maximum range for the slider. (You then click on the small white boxes that then appear in front of the component(s) they adjust, to adjust the range.)
You can also adjust the Next Variant button to high, medium, and low for different degrees of randomization (by clicking on the "..." button).
James
James
Filters: 46
Ah ok great, thanks for the info smile:)
mispost smile:D
IONclad
yeah, and the cool thing is that for things like blur you can give the controller a range of 1-100 and map it to a blur setting from 0 to 2... which will increment... well very slowly and accurately Awsum!
51 unregistered users.
