I'm falling asleep between renderings smile:D LOL.....
You can do certain refraction type effects with offset if you know what you're doing.
Low settings?
Low settings?
Not exactly.
Why don't you post the filter that's going too slow and I'll see if I can make it faster.
The solution is to keep the Refraction subtree simple.
Yeah, I've come to realize that the hard way smile:) .....and have learned to stay away from the surface result when using it.....
Thanx smile:) I'll try to clean up some of the carnage and get it as close as possible to what I want.....and try to get it posted here tonight.....
IONclad
now, only if I could see lightspeed refraction when I looked out my window... now THAT would be a neat trick.
53 unregistered users.
