Tiffle
I would find components to extract and assemble Lab channels very useful - particularly if a single component could handle all 3 channels as discussed in another thread...
Quasimondo
Quasimondo
Filters: 32
I second that.
I'll ask the programmers. Any specific reason you need it for?
vladimir,
LAB is becoming more and more accepted and used and even preferred as a good way to clean up photographs. because of the way LAB separates its channels it's apparently easier to do some things. i dont use it, but i've certainly seen a growing use on retouchpro. you might ask byRo. i know he uses it from time to time.
craig
Tiffle
Most of the images I take benefit from at least a small amount of post processing in CS2. Since learning about Lab and its use for post processing particular types of image from the book "Photoshop LAB Color" by Dan Margulis, I now use the Lab color space to post process upwards of 75% of my images.
By providing access to Lab channels in FF I could quite easily create a very powerful and useful filter that would certainly meet maybe 95% of my needs for post processing in CS2. Such a filter would also enable those with only a little experience to access the remarkable power afforded by using the Lab color space.
Tiffle.
14 unregistered users.
