| Posted: April 16, 2007 8:04 am | ||||
i believe you can already do that, uber. try the impulse curve. turn on 'smooth' and play around. i'm pretty sure that was the curve that would do this.
| Posted: April 16, 2007 1:59 pm | ||||
| ssamm |
Maybe what would be good is if there was a "formula" curve where you could write your own math formulas to make curves somewhow...
| Posted: April 16, 2007 3:48 pm | ||||
Anyway I think an inverse curve op component would make more sense (than just an inversed sine curve) because it would be useful in other situations. |
| Posted: April 16, 2007 7:28 pm | ||||
Administrator |
A scipting component would be even better. |
| Posted: April 17, 2007 8:51 am | ||||
| Posted: April 17, 2007 9:17 am | ||||
This is coming soon right?
| Posted: April 11, 2009 3:10 pm | ||||
Interesting idea! But what happens when you hook up the impulse curve (default settings) to that inverse curve op? How will the result look?
| Posted: April 13, 2009 6:50 am | ||||
| Posted: April 13, 2009 1:28 pm | ||||
Yep, as one big antisurjective provocative reaction! |
| Posted: April 14, 2009 3:27 am | ||||
By making something inverse, you just reflect it over the line y=x, so an impulse curve (I used a bell curve, close enough) would look like the red curve in this picture (the blue being the original, and the black being the axis of symmetry). Obviously this is not a function, so I don't know how this inverse tool would work...
| Posted: April 14, 2009 3:36 pm | ||||
| Posted: April 15, 2009 1:51 am | ||||
Ah, clever - some sort of integral I guess? I noticed the result was flipped, I think the source curve needs to be inverted and reversed first. See attachment. Inverse Curve 2.ffxml |
| Posted: April 15, 2009 4:37 am | ||||
12 unregistered users.
