Jozvex
Hi guys! I think it would be great if you could perhaps right click on a node and choose "ignore" (or mute, or passthrough etc) so that you can compare the result with or without that link in the chain.
Also, it would be cool if you could drag a node over a 'noodle-thing' connecting two nodes and have the node inserted into the chain. If the connection wasn't so straight forward (ie the inserted node has multiple inputs/outputs) it could 'grey out' the node until you click on the property/attributes of the node you want to use.
Hmm that got a bit complicated sounding but hopefully you get the idea?
Hippotizer
Hippotizer
1) since a component can be dependant of multiple inputs, there is no simple way for bypassing it. but it could be done by just outputtting black (for 2d) or zero (for values).
2) can you tell me which component has more than just ONE output?
Jozvex
1) Well, perhaps it could go like this:
Step a) Right click on the node
If the node has only 1 input:
Step b) Select 'Passthrough' from the context menu and it will send that input straight through to the next node upstream.
If the node has multiple inputs:
Step b) Hover the mouse over the 'Passthrough' option and choose an input to pass on, from a sub menu. That sub menu could have an option like 'void' at the end of the list which means black/0.
2) None at the moment that I'm aware of.
This is already planned. We even tried to implement this in the first beta but it didn't make it due to the amount of work involved. I'd like to have this feature too.
20 unregistered users.
