I would really help, especially in more complex filters, that the connectors to and from a selected component are highlighted (ie a different color).
Their already color coded aren't they? That could be confusing.
Slurm
Filters: 3
How about a bold black border around them instead then?
Sjeiti, you mean that the connections should be highlighted on mouse roll-over?
It doesn't have to be a totally different color, it could be just a darker green or darker blue.
Something like this maybe...
That could be a useful feature for deciphering those spaghetti-jumble type filter constructions that some authors create. smile;) smile:D
Maybe the connections could become highlighted in the same way as selected components?
If I remember correctly, the code for this is already there, but it isn't activated -- I didn't like how it feels when turned on. This is on our list and we should see this in future versions (or maybe updates).
interesting idea. not sure i want the lines brighter than the components and nodes, but i wouldnt mind being able to tailor the color of certain lines. i often do 'legs' in my filters, where one set of components does something and that's one leg, and another set does another. if i could alter the colors of one leg to be one color and another leg to be another color, it might help in certain situations.
however, i do like that curves use blue and only curves use that color. so, a bit of discretion is going to be necessary here.
31 unregistered users.
