neil
The ability to zoom the viewport that contains the filter network is a must, especially considering the fact that one cannot re-size the UI elements. Another idea I have seen beofre is to have a small plan overview so you can quickly jump to nodes across the network.
-neil
The zoom is already planned, but don't expect it anytime soon. And we will think about the pan overview -- looks like many users would like to have this feature.
folks can help this a tiny bit currently. you can resize the components! look in 'view' on the menu bar while in the editor. you'll see, i think it is 'thumbnails'. open this up further and you'll see three options, small, medium and large. simply hit the small and it does help a bit.
but yes, i'd like a zoom on the edit window also.
craig
vladimir,
here's an option that might be easier to implement. how about being able to print out the components window in block form, including the lines between each component? just a simple little line drawing with labels on the component blocks would be sufficient. one would then have a flowchart similar to a coding flowchart in hard print and be able to see things at a glance. it's very easy to get lost in your train of thought with components all over...trust me, i know smile:)
craig
