Filters: 712
I'm sure that many filters creators would like to have something completely new to play with.
Making something completely new would probably pass through having completely new components.
Then we should help the FF team to understand precisely what kind of component we may want, giving them some clear idea.
I don't mean to give them the code and let them simply add it. But at least doing a little bit more than simply saying "I want a 3D environment", because it would be a too huge thing to do and it doesn't simply require a component.
Then, let's post below this message some component idea, and let's see what FF team can do.
New components are high on our to-do list. I hope at least some of them will make into FF13.
Filters: 712
Thanks GMM. smile:D smile:D smile:D
Filters: 712
As for me, a Bomber with not overlapping particles, if it is possible to do, would be a great thing to do. It would open a lot of new possibilities. Many creators tried to obtain it in more or less complicate way, but the results are too slow and not satisfying.
+1 on non-overlapping particles in Bomber/Bomber+. I have also wondered about allowing particles outside the 0...1 particle space for Bomber/Bomber+. I suspect this is probably a stretch code-wise or impossible, but I can dream. My other dream is somehow making more grey inputs into green ones, or a component that adapts regular values into grey inputs.
Beat
Beat
I would like to propose the following new components :
Components that can do basic calculations, like Adding, Subtracting,Multiplying and Dividing.
I know that this can be done with RGBMath components, but they are overkill and unnecessary complicated for the purpose that I envision.
I would like to have the new, simple arithmetic components to make adjustable dependencies for control values.
E.g. I have 2 Threshold components, parallel and will blend them.
I have 2 Sliders A and B to control the 2 threshold values. Now I would like to make a third slider C, that moves both Slider A and Slider B up and down, but keeping the same difference between Slider A and Slider B.
In general, to be able to setup more complicated slider networks to control the actual calculating components.
Filters: 712
Is there any chance to see in this update a selection in the Bomber for overlapping / not-overlapping particles?
I absolute agree and would be the greatest thing the bomber could have because it would really change everything and would be possible a huge new way to use bomber in a great way, and would be a big thing to have against others
Is not needed to make it perfect no-overlapping, it could be done with a circle shape like it is done for circle packing, because inside the circle are included all the other polygonal shapes
A possible best way maybe and possibly would be with a spacing slider so you can customize the space that is between particles and adjust as wanted, but of course I am do not know if it would be possible, so you can do it in the best technical way you may like and want
Thanks very much
39 unregistered users.
