KenS.
It seems that FF 11 Plugin work with PaintShop Pro 2022. Does it work with PSP 2023. I can't seem to get it to install.
KenS.
Ok I got it working with Paintshop Pro 2023. Correction, it's installed, but still doesn't work. Re-installed PSP 2022 and re-installing FF 11 after install PSP 2022, adjusting the file path in PSP. Got it working. Did the same steps with PSP 2023. But get a error message, then when you close the message you get the second message. "Paintshop Pro Plug-in passed bad parameters". The codes change every time you try to open FF 11.
KenS.
Finally got FF 11 and FF 12 plugin to install without error messages in Paintshop Pro 2023.
12 unregistered users.
