John Foll
It would be nice to able to render an animated filter to Mp4 file. I can now manually import these into a Video Editor and create a video. It would also be nice in the view showing the image to click on a preview button which would show the animation. I know I can keep clicking the next button, but having an animated preview would make it easier to see how the animation looks before importing into a NLE Video Editor.
FF12 will be able to render an animated filter into MP4 and other popular video formats.
At the moment it's unlikely due to performance issues. The recommended workflow is to set your image dimensions to a small value like 300x300 so that it renders quickly, tweak the settings until you're satisfied with the result, then set the final dimensions and wait for the result.
John Foll
Where do I go and what do a click on the save to mp4? I thought all that could be done was to save to png files or other image files with numbers after their names? I looked thru the help a bit and that is what I saw. I may have searched a bit too.
Wait for Filter Forge 12. In FF12, select File > Render Animation and set the Output file(s) field to Video File:
https://filterforge.com/images/version...mation.jpg
30 unregistered users.
