Lucato
FF addicted
Ideas for Blue Components...
a) When using the Switch blue component it should NOT show the sliders that aren't in use or weren't selected from the selector(See the image attached below). So, the sliders "x" in RED should only show up when the user select its source (Source 2). If I use the 12 sources with 12 different curves and create a slider for each curve settings I will have thousand of sliders that will show up, but won't have any effect over the result once I haven't selected them and just one source. Well, just a suggestion.
Yes, if memory serves, something like this has already been suggested, but the infrastructure for this isn't in place. It would require a serious redesign.
62 unregistered users.
