SimonKeating
I have a few suggestions that would improve the program:
-Edit size when using Save Image As. Currently it just seems to save at a couple of different sizes when either in draft mode or final mode. Its often unclear at what resolution the image will save as. It would be good if this could be changed or at least the program tells you what size the image will be saved at.
-Save/Render Multiple Images. The ability to select multiple artboards and render them all out in one big batch would be great then I can just leave my PC while it renders all the images. Currently I need to manually render or save out each one, one by one which is very time consuming for me.
Simon
First: you set up the image before you apply a filter, not after that. Please use the Image > Blank or Image > Open menu.
Second, you are surely able to render and save multple images via the File > Export menu.
angelize
angelize
Filters: 17
All I am able to do in the file export menu is render all the maps to a single preset. What I would like to do is to be able to select a batch or presets and simply export them all at once to my pc. For example I have a filter with about 20 or so different paper textures it would save so much time for me to export them at once.
I am aware of the command renderer but that is clunky and simply too much work to have edit xml files.
why not have it so you can just select all the preset and have a render all option in the prest menu which then would bring up a dialogue that would allow you to choose just images or all the maps?
note: I'm using FF 9
Edit: I just found a thread about Easy Render, I knew I had seen that someplace. I am using that and it is working well, but i still don't see why FF doesent have a user friendly interace like that for the command renderer built in to the program.
