I think that the Stretching an Image by CFandM is very useful and helpful to modify, distort or change an image or result of FF, and Is really handy
So I think it would be very good if this could be added as default component included directly inside the list of FF components and have it there for everyone that uses FF Because most usually is that do not know that this Stretch filter exists already and even if they have it and use it you CAN NOT use it directly because you have to AS IT IS NOW AVAILABLE 1 - Save and close the filter you are creating carefully not rewriting any previous presets 2 - Search for the Stretch filter 3 - Open it in Filter Editor 4 - Select all the components and copy them 5 - Search for the filter you want to use it 6 - Open the filter where you want to paste it in Filter Editor 7 - paste them and replace the image component with your own or with any FF result INCLUDING IT INSIDE THE FF COMPONENTS LIST That is all, so you save much time and do not need to spend time closing and searching for it in another filter If you already have your filter already open in Editor , what is the normal and usual thing, then instead of 7 steps it would be reduced to just ONE point 1 - just go to the components search and type str and it will appear the stretch component and put it where you need SORRY, DO NOT KNOW THE TECHNICAL DETAILS Sorry that I have no idea and do not know nothing about how the components are already built inside FF and do not know if a filter can be converted easily and without much work into an FF component. |
| Posted: November 20, 2020 2:17 pm | ||
29 unregistered users.
