Please, I want to suggest if it would be possible that in Filter Editor when you paste any component(or group of them) that instead of appearing in the center of the screen it would appear instead just under or near the mouse pointer is.
You may have this optional in the menu, and have option to put in the center or below the mouse pointer
This way you could control exactly where you want that the pasted component will appear and avoid having to search for it.
There are many times that the center of the screeen is already filled with many other components and when pasting it is overlay over the others and is difficult to see it and have to guess where it is. Many times I have to paste it in a empty area away fr om the others and then travel back to where it should be
Also even if the space is empty and visible, you have to go where to the component has been pasted, select it, and move it to the point where you want to use it, so it would be much better if it could appear directly wh ere you want to use it by using the mouse pointer in the place that it should appear.
Thanks very much and would really much that this could be possible and think is useful
30 unregistered users.
