I want that I could have for example 15 or 20 filters that have a custom specific preset, and be applied automatically in batch render to the same image and output the results to a folder
For example
1 - Sel ect one source image
2 - Select a single preset of each of the 15 or 20 filters
3 - Render the results of that preset of each filter using the source image given and save it on a folder
If you want to use more than one preset of a preset you could repeat selecting the same filter with another preset.
I think that it would also depend on which kind of filter is used and if inside the filter the source image is loaded through an image component (which is automatically assigned and loaded) or through a color control that do not know if this would be also able to be assigned automatically
I think that this was already possible using the some of the available external Batch tools but would be really good that it would be included by default in FF software itself.
MULTIPLE SOURCE IMAGES
Also if possible would be good that instead of only using a single source image it could load all the images that are in a custom folder and apply all the same filters and presets selected in the same was as above
For example
1 - Choose a custom folder that contains all the source images that you may want to render so then FF would start to Load the first source image file fr om this custom folder
3 - Render the results of that preset of each filter over each one of the source images given and save them on a folder
