SturgeonGeneral
SturgeonGeneral
I would be overjoyed if the Seamless Tiling checkbox wasn't defaulted as ticked. Most of the time, that is not the option I need. And the few times I do, it would be easy enough to tick that check box then, rather than having to uncheck it every single time I try to use this awesome program. If you don't need seamless tiling, but the checkbox is defaulted ticked, we have to keep toggling back and forth between Presets and Settings just to see if it is the effect we are after.
emme
Seamless tiling is off by default in the filter editor. It's up to the filter creator to set it on. If you want seamless off by default, you can edit the filter - go to filter controls, uncheck seamless tiling and save the filter.
SturgeonGeneral
SturgeonGeneral
Thank you sooo much for this. I had no idea where to even begin looking for this, yet alone how. I think you may have just opened up a whole new world for me.
Whoops... I just tried this on your Rough Wood Planks filter and now all the presets are...gone. Looks like I will need to do some playing to figure this out.
emme
Great! The presets should still be there, but it might take a while to re-render the thumbnails.
15 unregistered users.
