MKBreuer
MKBreuer
Filters: 47
I often try to place some lines with offset from the center.
Therefore i use an external image to have some needed guide lines.
It would be great if FF have a golden ratio component by itself.
Like center, thirds and other guide lines.
Just a simple visual help ....
(maybe similar to the guide lines for the blender camera)
Just simple, but not simpler. (A.E)
Well, maybe It may not be exactly what you may want, but here is a filter that shows the Golden ratio
Here is the filter
Fibonacci - Golden Ratio
maybe you could use this filter without the numbers as shown here, as an overlay for the filter you may want. I mean include this filter inside yours and use it
The golden ratio is also called the golden mean or golden section. Other names include extreme and mean ratio, medial section, divine proportion, divine section , golden proportion
The Golden Ratio: The Ultimate Guide to Understanding and Using It
the filter is called Fibonacci, because is made to show the Fibonaci spiral that shows the golden ratio, is explained in the link shown here
FilterForge by principle isn't a layout program. The design of the program isn't intended for that sort of precision. FilterForge is a texture and filter generator. The primary goal of this program doesn't stem from doing layouts.
I'd rather see this feature implemented elsewhere more useful and practical.
