siSINka
In settings is only "root" of all logical discs. But I don't want to have temp files there, for example in Total Commander is root full of files..
Solution: to edit file:
c:\Users\yourname\AppData\Roaming\Filter Forge 8\Options.xml
Change this:
<TemporaryFilesLocation value="C:\"/>
(for example to)
<TemporaryFilesLocation value="E:\Temp\FF8"/>
After opening FF8 is in setting dafault temp location, but these temps are in prefered directory.
See screenshot.
@devs: can you add this feature?
This is possible using the SUBST command:
run the command line as administrator and enter the following command:
SUBST X: E:\Temp\FF8
Your folder will be mapped to the X drive letter which you will be able to select in the program settings.
