Has this been mentioned yet?.... I've experienced this numerous times. I spent ages making nice presets, then I decide to tweak something on the filter itself. Instead of the default preset I have some other preset active. I tweak the filter, save the filter and the default preset is overwritten by the current settings smile:evil: .
Zephos
Xyni says "Maximum w00tness!"
Filters: 31
I've experienced this quite a few times myself and agree. It does kind of make sense that saving will override the default, but I know personally that for every time I remember this fact, there are two times when I forget X_X and bye-bye main-gun preset X_X. Since it's saved too, it's something that can't really be undone. It would be nice if there was an option to lock the default preset to not update/change when saving.
-Zephos
Yeah, that's a good point.
Sjeiti, this is complicated. We tried numerous approaches to this, and went with the current one simply because it was 'less evil' than the others.
even though i've goofed up like this also, i'd prefer the current method wasnt changed. this is a 'user error' and when programmers start trying to correct user errors with code, we tend to get goofy programs.
i find that making a duplicate of the default tends to help this situation out. just make a copy of the preset somewhere down in your presets and if you wipe the default (like i did yesterday), you've got a backup.
what i'd rather see is a warning message when you hit 'save filter' that prompts you to save as another name for the filter so you dont overwrite an existing whole filter from the editor. (and i think this was mentioned by someone else months ago and made it onto the list).
67 unregistered users.
