I need a reverse switch, one that switches the output instead of the input.
if you wanted to make it a multiple controlled input and output, that would be fine, too.
I'd like this by tomorrow smile:D
What does a turned off output look like? transparent black?
You can just drag multiple output lines to blends or threshold or lerp or whatever that lets you toggle btwn input and transparent somehow.
However.... multiple outputs from groups.... (heavy breathing)
Beliria
Wouldn't that be like an on/off switch type thing?
(Tries to get into Craig's brain for a better look and gives up)
I think that you need to explain it more (at least for me) to understand what you want, and why you want it, I mean the purpose of this and what you want to do with this
quite honestly, I've sort of forgotten, but I think I was talking about the switch component. you cannot control the output from that component unless you run another line and even then you cant switch one output line on and off. I think that's what I wanted, to be able to have multiple lines going from a switch component and be able to control which of those lines would be active or not FROM the switch. yeah, that makes sense now regarding my original post, because you can switch the input lines from one to another within the component, but you cant switch the outputs one from another internally.
