Shawn Olson
Technical Artist
The default pixel dimension of images being 600x600 seems a little odd. Should it not default to 512 or 1024?
Also, I think the user should be able to set their desired pixel dimension in the global options.
Also, I feel that the function to render maps should give the user an easy way to modify the global setting.
Shawn Olson
USD Product Owner, 3ds Max & Maya @ Autodesk
Tuxmask75
Just learning FF
I second this !
Stephiebunnie
Stephiebunnie
Agree
chrisd
... and a setting for a custom size that will save with the filter as well.
On a related note, the library previews are 512x512, which doesn't match the default 600x600 in the actual program. That can be pretty annoying sometimes.
