I thought that in the same way as there is blend component that is for only components, and then also there is the multiblend component for more than 2, there could be also a new Switch component for only two components with a checkbox to choose One or the other component linked.
1 - It could show only ONE of the components in the Settings, for example, if you connect two color controls it would only show one of them 2 - It would be a cleaner design when creating the filter, as the switch component now is big and takes much space, and if you only want to make a simple 2 components switch it looks too big for me. 3 - It would be a little bit easier to use and faster to make a switch with two components, just connect the two components and the checkbox and it does not need any selector thanks |
| Posted: February 23, 2017 3:20 am | ||||
xirja
Attach a HSB component at 0 H, 0 S, 50 B, to the Threshold 'Source', and then a checkbox attached to 'Threshold' will select between the high and low.
edit: as far as
that would require intelligent settings, and before that we would already have a drop-down menu for blend modes, etc.: https://www.filterforge.com/forum/read...=9&TID=632 _____________________________________________________
| Posted: February 23, 2017 9:25 am | ||||
| MKBreuer |
Mayby as a group switch component, who shows only the settings of choosen group?
This would be very handy... Just simple, but not simpler. (A.E) |
| Posted: March 12, 2017 7:44 am | ||||
